Rideking 32 #1 Posted July 9, 2013 I've been on the search for a snow thrower for a while now but they seem to be quite scarce here in Missouri! I took our vacation to Minnesota as an opportunity to seek out a thrower and came across this thrower. It appears to be in pretty good shape, however I can't find any identifying tags or numbers? Any thoughts on to what model this is? Share this post Link to post Share on other sites
stevasaurus 23,619 #2 Posted July 9, 2013 Looks like a ST-376 to me. The 6 is the year (1966)...37 is the width. Look at this link. It has the guard over the shoot turning handle. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,013 #3 Posted July 9, 2013 The 1974 model 6-6213 was the first model to use side extensions with the front straight return so it's older than that. That leaves 1966-1967 model ST-376, 1968 model 6-1211, 1969 models 6-6211 plus 6-9111, 1970-1973 model 6-6212 plus 6-9112 or 6-9113 Cable is wrapped around the 1/2" crank shaft. Spool was added to the shaft in 1975. Garry Share this post Link to post Share on other sites
Rideking 32 #4 Posted July 9, 2013 What completing kit would have been offered with the st-376? Mine appears to hook up to the 310-8 with no problems, did someone update the completing kit to a newer style? Should I expect any problems running it on the 310? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,013 #5 Posted July 10, 2013 I listed all the 37" models which was not the correct thing to do. It must be the 6-6212 with the 6-9113 kit to fit the front quick hitch new in 1973. In 1974 they included the extensions making the same unit 42". Garry Share this post Link to post Share on other sites
