sjgriz4 0 #1 Posted July 4, 2013 I am going to buy a new set of ag tires for the rear of my 416. I will be using it mostly for mowing and gardening so I would like to have wider tires so my question is what sizes can one get on the orginal rims without rubbing on any metal? Share this post Link to post Share on other sites
papaglide 542 #2 Posted July 4, 2013 I am curious also. Share this post Link to post Share on other sites
Sparky-(Admin) 24,107 #3 Posted July 4, 2013 Ag's seem to only come in 8.50 and 10.50 widths to the best of my knowledge. I think the 10.5's will fit clearance wise but your rims (if they are factory originals) will be only 7" wide and the 10.5's will bulge out and you may not get a nice flat tread pattern, which defeats the purpose of the wide tire. Maybe try to find a pair of 8.5" wide rear rims like what came on the 520 and the GT1800's and mount up 10.5 rubber on those, this way you will still have the turf tires if you ever wanted to swap over. Mike............ Share this post Link to post Share on other sites
baerpath 517 #4 Posted July 4, 2013 Carlisle AT101 Chevron Tires 24x12x12 are the best you can get for use on the lawn. Also they'll go on your rims Share this post Link to post Share on other sites
sjgriz4 0 #5 Posted July 4, 2013 Carlisle AT101 Chevron Tires 24x12x12 are the best you can get for use on the lawn. Also they'll go on your rims The 12" will fit on my rims and be ok? I like the way the look http://www.amazon.com/Carlisle-Tire-24X12X12-AT101-CHEVRON/dp/B001OK4GPU Share this post Link to post Share on other sites
papaglide 542 #6 Posted July 4, 2013 I have the stock rims on my tractor. That being said, the 8.50's would fit and have plenty of clearance? Share this post Link to post Share on other sites
baerpath 517 #7 Posted July 4, 2013 Product Code: 560352 BRAND: CARLISLE SIZE: 24X12.00-12 TREAD: AT-101 CHEVRON DESCRIPTION: 4ply ( load range "B" ) Tube-Less LAWN & GARDEN - Golf Cart - Go Kart Tire NHS Height: 23.9 inches Width: 12.2 inches Rim Diameter: 12 inch Recomended Rim Widths: 8 to 10.5 inches wide Maximum Weight Carrying Capacity: 1,700 lbs. per tire @ 20 psi. @ 10 m.p.h. NOTE: NHS This tire is a Non Highway Service Tire. The AT-101 CHEVRON Tire is MADE IN THE U.S.A. Share this post Link to post Share on other sites
