welderman85
pulling LT 1137 motor
welderman85
I just blew the motor up in my LT 1137 I was given a 12 horse to swap in but I am not sure how to go about unhooking the clutch and pulling the motor do I have to pull the sterring shaft. thanks for any help. thank you
SousaKerry
Its been a long time since I pulled the motor on mine but I do not remember pulling the steering apart.
The PTO has to be removed first once you drop the lower half off the cone pulley is held on with a bolt into the crank shaft.
welderman85
I got it last night thank you very much had to use a 3 jaw puller to get the top half of the pto off put other than that not bad. thank you again
