Shanepm19
520h tire question
Shanepm19
I am trying to find out what the biggest tires are i can fit on a 1996 520H without any modifications. It has the swept forward axle and 48" side discharge deck. I want to run the tallest amd widest tires on the front and back as possible. Thanks in advance.
Dirtdog524
I have a 1990 Wheel Horse 520 with 26x12x12 tires. Seems to be more than enough tire for any application you might need
cdsl810
Did you mount the 26 inch tires on wider rims or the original 8 1/2" rims? I know you can use 24 x 12 x 12 tires on the 8 1/2" rim without a problem, just not sure about the 26s
