WHwest8597 85 #1 Posted June 30, 2013 I'm having problems with the manual lift on my 314-8. I messed with the dial height adjustment, but when I lift the handle I'm not getting any lift when I'm using the rototiller and little lift with the mower deck. Share this post Link to post Share on other sites
wallfish 18,630 #2 Posted June 30, 2013 The dial adjustment will only limit the low end on how far you can drop what ever attachment is on the tractor. It will not effect how high the attachment can go. If the attachment is not dropping far enough, you will need to loosen (turn counter clockwise) the dial height knob. Was it working correctly before you adjusted the dial? Share this post Link to post Share on other sites
leeave96 490 #3 Posted July 2, 2013 The dial adjustment will only limit the low end on how far you can drop what ever attachment is on the tractor. It will not effect how high the attachment can go. If the attachment is not dropping far enough, you will need to loosen (turn counter clockwise) the dial height knob. Was it working correctly before you adjusted the dial? +1 Check for a broken cable, cable attachment clevis on each end of the cable. Good luck, Bill Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,757 #4 Posted July 2, 2013 There is a chance you have the attachments connected to the wrong arm on the bellcrank to lift them. Go here https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro and use model number 21-14K801. Then open the Manual Lift Linkage page where it shows what connects where on the lift. Garry The Manual Lift Linkage is a link to the page. 1 Share this post Link to post Share on other sites
