tom hart 0 #1 Posted June 27, 2013 I need a PC Board for a wheel Horse 312-8 ! Where can I get one.? Share this post Link to post Share on other sites
Jeff-C175 7,207 #2 Posted June 27, 2013 Tom, why do you keep starting new threads asking the same question? Share this post Link to post Share on other sites
rmaynard 16,699 #3 Posted June 27, 2013 There are 10 different models of 312-8, form 1985 to 1994. Which one do you have? What is the ID number on the tractor? Share this post Link to post Share on other sites
nylyon-(Admin) 8,546 #4 Posted June 28, 2013 Also, if you're handy perhaps this thread would help: and this one Share this post Link to post Share on other sites
wheeledhorseman 579 #5 Posted June 28, 2013 It would be helpful to have a bit more info about the reason for your quest. If, for example the board is missing from your tractor then we need to work out which type of board was fitted. For example, if the engine has an oil pressure sensor then the board you need will have a chip on it to flash the oil warning lite - some boards did not have this. On the other hand if there is a board on your tractor but it's misbehaving in some way then knowing exactly what it does / doesn't do would be helpful. For example some strange behaviours are often due to poor connections, faulty safety switches and wiring etc.in which case a replacement board may not solve the issues. There are lots of guys with a wealth of experience on the forum only too willing to chip in and help if they can but the more info you can provide the better the help and advice will be. Andy Share this post Link to post Share on other sites
