Kelly 1,038 #1 Posted June 26, 2013 Does anyone know off hand if a crank from a older 8hp Kohler will be a direct fit in a Magnum 8hp ?? Thanks Share this post Link to post Share on other sites
WH nut 553 #2 Posted June 26, 2013 If I remember the specs right they are the same, but you might want to double check it. Share this post Link to post Share on other sites
Fordiesel69 274 #3 Posted June 27, 2013 The K series will have a threaded section where the nut will hold the flywheel on. The magnum rather has a threaded hole in which a bolt holds the flywheel on. If you swap this hardware, then yes it will work. The flywheel won;t care if it is a nut or a bolt. 1 Share this post Link to post Share on other sites
