Kelly
Crank swap 8hp Kohler
Kelly
Does anyone know off hand if a crank from a older 8hp Kohler will be a direct fit in a Magnum 8hp ?? Thanks
WH nut
If I remember the specs right they are the same, but you might want to double check it.
Fordiesel69
The K series will have a threaded section where the nut will hold the flywheel on.  The magnum rather has a threaded hole in which a bolt holds the flywheel on.  If you swap this hardware, then yes it will work.  The flywheel won;t care if it is a nut or a bolt.
