pntn4qrtrs
1986 Wheel Horse 414-8 any information deck belt
pntn4qrtrs
I have a 414-8 1986 I need the correct belt number for the deck belt. I also need a copy if the owners manual. If anyone can assist in this I would most appreciative.
kj4kicks
Deck belt depends on the deck, not on the tractor.
pntn4qrtrs
I measured the deck from side to side which measured a 42
Sorry it was a 46 inch deck
Tankman
Welcome to the forums.
An owners manual is available here, download, in the Manuals section; http://www.wheelhorseforum.com/files/category/11-1985-2007/?sort_order=ASC&sort_key=file_name&num=10&filter_key=all&st=10
Which mower deck do you have? Any ID on the deck itself? :eusa-think:
gwest_ca
Decks are sized by their width of cut - not the width of the deck.
Width of cut?
How many blades?
Side or rear discharge?
You can get to an attachment list here
https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro
Type in 414-8 and select the list for your year. The deck models listed are just some of the models that fit it so you may have sometthing different as far as bearings go but the belts should be the same.
Garry
