dgk7575 0 #1 Posted June 24, 2013 I have a 1984 LT 1100 5 speed Wheel horse lawn tractor that needs new rims. The tire size is 13 x 6.50-6. I have new spindles but need the rims as they are badly worn. The rims have been discontinued by the manufacturer so I am having trouble finding replacment rims. If you have any ideas, I would be appreciate it. Thanks, Have a great summer. Dave dgkplus4@hotmail.com Share this post Link to post Share on other sites
groundhog47 347 #2 Posted June 24, 2013 I'll email ya on some I have, not WH Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,499 #3 Posted June 24, 2013 There is a way to determine what other models used a part - in this case a 109518 wheel. Go to http://www.milacalawn.com/pages/OemParts Select Toro consumer and enter the part number. Look for the number you entered in the list on the left if more than one comes up. Now click on the "Select Model" on that line to see a list of the parts lists that contain that number. Open each one and read it to make sure your part is used because these parts lists are shared by similar models so may have more that one wheel part number listed. Garry Share this post Link to post Share on other sites
groundhog47 347 #4 Posted June 25, 2013 Are the rims rusted through or just the bore/bearing worn out, If the bearing is not worn through to damage bore, a new bearing can be put in place when old one removed. Had a 4' that appeared bore-bearing part of rim and someone discarded for a new one, old bearing pushed out leaving a fine bore...just a thought before you have to spend $ on replacements. Share this post Link to post Share on other sites
