WHNerd 8 #1 Posted June 24, 2013 HELP Yesterday I was plowing the garden, all was going well, when all of the sudden the transmission started to slip. When you move the lever to engage tranny the tractor may move a little bit, both in forward and reverse or not move at all. Checked fluid ok, check belt ok, checked pulley on tranny ok.. Need some expert advice. I bought this rebuilt pump about 7 or 8 years ago and has worked flawlessly. Appreciate any help. Thanks 2 Share this post Link to post Share on other sites
pfrederi 18,800 #2 Posted June 24, 2013 (edited) Just to make sure this is on an Electro 12 and it is a Hydro-Gear transmission vs a piston to piston. Reason I ask is when the hydro-gear was discontinued some were replaced with piston to piston units. Also you said it was rebuilt, WH said the hydrogears were not serviceable... A hydro gear has a motor housing that looks like the number 8 when looking at it (It is a gear pump) Piston to piston units have a round motor housing face. Edited June 24, 2013 by pfrederi Share this post Link to post Share on other sites
daveoman1966 3,841 #3 Posted June 24, 2013 There are so many possibilities.... 1).. inspect the cam plate and cam on the front of the hyd pump. (item 58 & 59 in this schematic). CAREFULLY remove a couple items from the pump...CAREFULLY and KEEP EVERY THING CLEAN! ! ! 2) spring # 69 or 74 may be broken 3) Look at springs 76 and 78 too. 4) Be sure the push valve #61 is closed. 5) there is a small set screw at the top of item 57 which holds the cam in position...check it. 6) The cam #58 may be worn so flat that the cam plate 59 won't properly engage it. If you want to contact me further, my email is: daveoman@windstream.net 1 Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted June 24, 2013 I'd check the key(s) in the wheel hub(s) first. Share this post Link to post Share on other sites
WHNerd 8 #5 Posted January 27, 2014 Better late than never, your were right Terry, hub was loose! Thanks Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #6 Posted January 27, 2014 Cool! Did you finish plowing the garden...... or are you plowing snow now? Share this post Link to post Share on other sites
bowtieguy 334 #7 Posted January 28, 2014 And TT wins again....got to get up early to beat that ole boy..(although he had to wait since June 2013 ...must be time to plow the garden again!!!!!) 3 Share this post Link to post Share on other sites
formariz 12,051 #8 Posted January 28, 2014 And TT wins again....got to get up early to beat that ole boy..(although he had to wait since June 2013 ...must be time to plow the garden again!!!!!) Always timely, no nonsense, sensible non complicated solutions and to the point. A priceless resource in this forum in my opinion. 1 Share this post Link to post Share on other sites
WHNerd 8 #9 Posted January 28, 2014 I did get the garden plowed and now have plowed snow 3 times. Bought a GT 14 last summer and am looking for a snow blade for it. Thanks again, Terry Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #10 Posted January 29, 2014 You are quite welcome & I'm glad to hear your 'Horse is healthy again. Share this post Link to post Share on other sites
