55rj35jr 623 #1 Posted June 24, 2013 I've got gear winding and grinding gear noise in my trans it shifts and works fine just the noise I drained and flushed it and replaced the oil didn't help anyone have any ideas on how to quiet it down ? or do I need to replace the trans with a different one? thanks Share this post Link to post Share on other sites
can whlvr 994 #2 Posted June 24, 2013 good chance its a bearing,it needs to be replaced before it wears out what ever is riding in it(if its a bearing)could be worn gears too Share this post Link to post Share on other sites
sorekiwi 761 #3 Posted June 25, 2013 As Don said it is probably due to a worn bearing. Gear whine is a result of everything getting out of alignment, usually because a bearing has failed. If you catch it early enough a new set of bearings will save the trans. There are plenty of threads on here to show you what is involved. Share this post Link to post Share on other sites
