krazy_horse
B-80 Wheel Bearings
krazy_horse
Had a great time at the Big Show. I bought what I think is a B-80 axle from one vendor and two wheels from another. The wheels have no bearings and I would like to buy some from my local NAPA Auto Parts. Could you give a number to cross reference? Also do I need two per wheel? I tried to buy some at the show but the new parts vendors I spoke with either did bot bring any or just did not have them. I want to build a little pull behind surry. Thanks!! Jim    krazy_horse
groundhog47
Jim, front wheel bearings show part number 4999, same as C-120 and two per wheel, 1 3/8" od 3/4" id, Tulsa engine warehouse has them from just under $2.00 to a bit under $7.00, about four speed ratings, some where else saw them $4.95 ??Miller Tire?? I'll try to find some numbers>
groundhog47
Jim http://www.millertire.com/categories/wheels/parts/?sort=featured&page=2 Miller Tire bearings, if doesn't show is under wheels, parts, will be back after find TEW, 1st http://tewarehouse.com/7-04232?sc=2&category=356,
2nd http://tewarehouse.com/7-07477?sc=2&category=356,
3rd http://tewarehouse.com/7-04292?sc=2&category=356
None showed cross to 4999 WH and couldn't get NAPA cross to any Toro Consumer. Hope this will help and some of the go kart places have the 1 3/8" od  3/4" id bearings.
Did you get your diamond tread tire?
Edited by groundhog47
groundhog47
Ok, the new number replacing  WH  4999 is 110513 and all three of those at TEW show 110513 or 11-0513.
Miller is 1 3/8 x 3/4 /7/16 TEW 1/3/8 x 3/4 x 1/2 so if more sticks out shims may not be needed, if more sticks in should be ok. I believe it's one .015 and one .040 shim on inside between hub and axel stop ring.
krazy_horse
Thanks for the information Gerry.. I will find them  Monday You sure missed a good show. The weather was perfect and more Wheel Horses and parts than one could imagine.. I hope to attend next year! Regards, Jim   ...krazy_horse
Edited by krazy_horse
groundhog47
Jim, I'm leanin heavy on tryin to go. Would probably fall out with anxiety attack or short of breath heart palpitations! Glad ya got to enjoy it and glad ya got your tires and wheels.
