blackwater73 8 #1 Posted June 20, 2013 How do you get to the grease fittings to add grease and also lube the teeth on the 416-8 tractor? Share this post Link to post Share on other sites
Tankman 3,523 #2 Posted June 20, 2013 I find it easiest to remove one of the dash panels to grease steering gear. Also spray some penetrating oil on the shaft and shaft stop. I have also removed the steering wheel center cap and oil the top of the shaft, replace the cap. Good time to replace screws or nuts if required. I use Never-Seez® on the threads, always. A half pint of Never-Seez® lasts years. A little dab'll do ya. The 1/4-20 screws I have replaced with stainless Phillips head screws. I think they have a broader head but, they are easier to replace and/or remove new. :smile: Share this post Link to post Share on other sites
Callen 64 #3 Posted June 20, 2013 I think if you turn your steering wheel all the way to the right, you can get on the grease fitting through the opening under the battery. Share this post Link to post Share on other sites
Tankman 3,523 #5 Posted June 21, 2013 I think if you turn your steering wheel all the way to the right, you can get on the grease fitting through the opening under the battery. That is true! I just get carried away with PB and spray around when I remove a panel. :smile: Share this post Link to post Share on other sites
