jeremi3210 742 #1 Posted June 12, 2013 Does anyone know if you can convert a 1 inch axle trans into a 1 1/8 inch axle trans? Share this post Link to post Share on other sites
SousaKerry 503 #2 Posted June 12, 2013 Well you can swap the entire transmission, but if your trying to convert one transmission from one to the other I wouldn't bother. Share this post Link to post Share on other sites
jdog_kustoms 82 #3 Posted June 12, 2013 it can be done but you need a lot of stuff out of a 1 1/8 axle rear better to just buy the other rear Share this post Link to post Share on other sites
baerpath 517 #4 Posted June 12, 2013 You can convert a 10 pinion to a 8 pinion. Takes a little work but less than converting one with one inch axles. Share this post Link to post Share on other sites
stevasaurus 23,355 #5 Posted June 12, 2013 I would think that you will need to turn out the inside of the transmission axle housing to accept the new 1 1/8" outer bearing...and seal. Probably not worth it when you can get the trans halves for the 1 1/8" for not much money. Share this post Link to post Share on other sites
