deer_remington 2 #1 Posted June 11, 2013 I have a Wheel Horse C-175 Twin Automatic model 01-17KE01-22113 (i believe it is a 1980 model). I need help identifying the part number for the deck drive belt from the PTO to the deck. The deck is a 48" side discharge deck. HELP please. Thanks Share this post Link to post Share on other sites
Jeff-C175 7,207 #2 Posted June 11, 2013 I believe you need a WH # 102742 It would be #41 in this diagram, also shows the newer number of 94-2501 http://www.partstree.com/parts/?lc=toro_consumer&mn=05-48MS01%2C+48%22+Side+Discharge+Mower%2C+1980&dn=810172R1-72R10017-0009 Share this post Link to post Share on other sites
JackC 617 #3 Posted June 11, 2013 The numbers are: 102742 (old number) / 94-2501 (new number) See the following in the manuals section: Chart Tractor 1956-1999 Lubrication Recommendations, Drive Belt, Mower blade usage.pdf Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,875 #4 Posted June 11, 2013 I have a Wheel Horse C-175 Twin Automatic model 01-17KE01-22113 (i believe it is a 1980 model). I need help identifying the part number for the deck drive belt from the PTO to the deck. The deck is a 48" side discharge deck. HELP please. Thanks Your mower deck model number will be 05-48MS01 or 05-48MS02 or one similar to it depending when it was made. Record these numbers for future use. Parts list Operator manual http://www.wheelhorseforum.com/files/file/904-mower-rotary-1980-1983-c-series-mowers-om-810306r1pdf/ Garry Share this post Link to post Share on other sites
