dave in A.P. 4 #1 Posted June 10, 2013 Does anyone have a cross reference #for the metric bearing on a 37'' 2 blade deck? the toro number is 109996 but I was hopeing someone had a NAPA # or a skf. thanks alot! Share this post Link to post Share on other sites
SousaKerry 503 #2 Posted June 10, 2013 See if you can find the bearing number on the bearing itself or take the bearing into your local bearing shop and they can match it up. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,606 #3 Posted June 10, 2013 Part number 109966? Likely a 6203 RS with one seal. If you find a replacement with 2 seals pop one of them out. Garry Share this post Link to post Share on other sites
Don1977 605 #4 Posted June 10, 2013 If it is a 6203 RS like the 42 and 48" deck metric spindles. You can get it at a local auto parts, old Chevy alternators used that bearing. the ID is 17 mm the OD is 40 mm and 12 mm wide. Here is place to order SKF bearings. http://www.usabearingsandbelts.com/m7/1002325--6203-2rs-6203-open-skf-brand-ball-bearings-17x40x12.html Share this post Link to post Share on other sites
