dlhirsch 0 #1 Posted June 6, 2013 I have a Bronco 14 hydrostat model 1-0421-6 with a Kohler K321S engine that runs fine when under a load like going up hill. When I turn to go down hill the engine sounds like I turned the key off but so far has continued to run. Sometimes just idling it will do the same thing. I have replaced the fuel filter, spark plug, cleaned air filter and replaced the plug wire to no avail. Someone told me the other day it was transmission related? I would like to change the transmission filter and fluid. Can someone recommend a filter and type of fluid that I can get from a local auto parts store? Any input would be greatly appreciated. Thanks in advance. Share this post Link to post Share on other sites
Hodge71 691 #2 Posted June 6, 2013 Your Bronco is a 1971 model year. It has a Sundstrand 90-2046 hydrogear transmission with Mercon tranny fluid iin it from the factory. I would check the dipstick, if its got red fluid you're good to go, Get yourself some dexron mercon and a 1410 Napa filter. If its clear then it was changed over to 10W-30 oil. You'll still need the Napa 1410 filter though... Share this post Link to post Share on other sites
dlhirsch 0 #3 Posted June 13, 2013 Thanks for the information. The NAPA store was closed but another parts house cross referenced the NAPA 1410 to a WIX 51410. I assume this will work. Thanks again. Share this post Link to post Share on other sites
Hodge71 691 #4 Posted June 13, 2013 Wix is a good filter. As long as you, dont put a Fram or any other oil filter on it youre good. It must be a filter intended for hydraulic use only and both the 1410 and the Wix 51410 are. Share this post Link to post Share on other sites
dlhirsch 0 #5 Posted June 19, 2013 Thanks for the filter info. Share this post Link to post Share on other sites
chevyaddict83 39 #6 Posted June 19, 2013 I'm gonna jump in on this sincr its related. What is the average capacity of these transmissions. www.perfecttrimlawnandgardencare.com Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,875 #7 Posted June 20, 2013 I'm gonna jump in on this sincr its related. What is the average capacity of these transmissions. www.perfecttrimlawnandgardencare.com Garry Share this post Link to post Share on other sites
