starcraft150 0 #1 Posted June 6, 2013 Will a 60" mower deck from a 520h fit a D-160 with midmount tach a matic hitch. 1974 D 160 Thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,606 #2 Posted June 6, 2013 I doubt it because the front idler assembly is specific to the 60" deck and C-Series. This service bulletin was generated after the supply of original 48" decks for the D-Series was exhausted. Other 36" and 42" decks are also included. Garry Share this post Link to post Share on other sites
baerpath 517 #3 Posted June 6, 2013 It can and has been done you need to do some swapping on the hangers and the deck lift system Share this post Link to post Share on other sites
tommyg 154 #4 Posted June 14, 2013 If you give it a go, I'd like to know how you make out. I've dreamed of putting a 60" under my d180, replacing my somewhat fragile 48". I have the hanger assembly, so if it's just a matter of fitting that to the shell, seems to me it should work. No idea what belt size to use, though. Share this post Link to post Share on other sites
Hydro 131 #5 Posted June 16, 2013 If I'm not mistaken Hodge71 did it. He has a D and he mounted a 60" 520 deck on it. Send him a pm. Share this post Link to post Share on other sites
Shuboxlover 481 #6 Posted June 17, 2013 I have all the hanger hardware from a D if you are going to make this a go. Share this post Link to post Share on other sites
