raider10-8 9 #1 Posted June 5, 2013 is there such thing as a 2 piece pinion and one piece pinion? if so whats stronger. Share this post Link to post Share on other sites
racinfool40 203 #2 Posted June 5, 2013 yes the 2-piece pinions were used in the older 4-speed transmissions....the 1 piece pinions I think started in the early 70's 4-speeds and the high/low transmissions...the 1 piece are alot beefier and stronger than the old 2-piece ones....and they way the differentials are made you can,t swap them out either with out some machining work. MIKE. 1 Share this post Link to post Share on other sites
stevasaurus 23,517 #3 Posted June 5, 2013 (edited) Mike, if you got a whole differential that had the one piece pinions, could you just put it in the trans with no modifications. The existing trans had the 2 piece pinions...8 speed trans.?? I just talked with Raider 10-8 on the phone...my guess is you can swap out the differentials...not the parts inside. What do you think??? Edited June 5, 2013 by stevasaurus Share this post Link to post Share on other sites
racinfool40 203 #4 Posted June 5, 2013 Steve..I am pretty sure if you find a 4-speed out of a 1971and newer tractor they have the 1-piece pinions....trans #..5080-5084-5085-....Workhorse,commando 800...and the B-80 4-speed tractors....they are the same trans as the older 4-speeds just better differentials. I have put the better differentials in the older tranny's....I know of 2-701's and a 702 that have the newer differentials in them.... Mike. 1 Share this post Link to post Share on other sites
thehorseman 0 #5 Posted June 9, 2013 i put a diff in my trans. it has 1 peice pinions but i blew all 4 of them up to peices. so i got a used diff with 2 peice pinions threw in my axel shafts and all was good till i drove the tractor and the axel is solid during steering and im not sure y? good thing its a pulling tractor it only has to go straight! lol Share this post Link to post Share on other sites
racinfool40 203 #6 Posted June 9, 2013 You have the pinions installed wrong....1 up and 1 down they have to be opposite all the way around or it will lock the differential. 1 Share this post Link to post Share on other sites
thehorseman 0 #7 Posted June 10, 2013 o ok that works. well im not gonna take it apart again especialy since i got the parts for only 20 buks if im pullin the tranny apart again ill do when this diff blows up and put a 8 pinion rear in it Share this post Link to post Share on other sites
