Andrew Martin 0 #1 Posted June 2, 2013 Can anyone tell me the part numbers or the lengths for the drive belt from PTO to deck and the length or number of the mower belt. Thanks Andrew Share this post Link to post Share on other sites
Jeff-C175 7,207 #2 Posted June 2, 2013 On the "853" I presume? your 'favorite model' ? Share this post Link to post Share on other sites
Andrew Martin 0 #3 Posted June 2, 2013 the Belts are on a little B80. With a 38" rear discharge deck I have No numbers to Go by could You tell Me the length of the Main belt and the mower deck Belt? Thanks Andrew Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,009 #4 Posted June 2, 2013 Andrew, Do you know the model number of your tractor? Should be an ID plate up tight to the bottom of the dash housing. It will have the model number and serial number. The B-80 was built with 2 different frame lengths resulting in 43-1/2" wheelbase commonly called a medium frame and 45-1/2" wheelbase long frame. Possible the mower deck has a 36" width of cut? Washago? Just south of Gravenhurst? If so I'm an hour north of you. Garry Share this post Link to post Share on other sites
