ricksrj58
not sure about this cab idea,what do you guys think
ricksrj58
i picked up this curtis cab at auction and now i am not sure about putting it on my D.the front of the cab will sit right above the hood and to open the hood you have to flip the cab backwards.and i am not sure about how to mount the front of the cab.
sscotsman
eh..doesn't look very good to me..
to make it fit, you would have to hack up the tractor a bit..not worth it IMO..
and even then, it still wouldn't really "fit"..if you know what I mean..
personally, I wouldn't do it..
Scot
illinilefttackle
I'll bet if you notch out the support rails at the sides of the front of the cab-right under the window-then bend the flat panel back at the level needed to clear the window over the steering wheel, but miss hood-then weld supports back together- I think the hood will open then too-hope you can see what I'm saying. Thanks-Al
AMC RULES
I don't know...gonna need  a lot of work to warrant being installed on that tractor.
ThreeHorses
My son has one for his 520H, it hinges at the back and just sits on the hood on a rubber cushion as I remember. It doesn't actually bolt or mount to the tractor in the front.
you might send WorkinHorses a PM and ask him about his.
Ken B
Is the cab complete with doors or curtins? If not, its not much more than a sun shade....
ricksrj58
the cab came as you see in the pics but i do have red canvas i was going to use if i use this cab.
notching the rails and bending the front panel is a good idea,i think it still needs to be mounted solid somehow and now that it is sitting on the tractor i do not if i like the look of it.
varosd
it could look like this in the end....
  • Like 4
baerpath
Theres a D cab for $50 in the classifieds on here (It's in PA too)
Save Old Iron
little bit of tinting on the glass - and some AC - great combo on those 90+ degree SPF50 days - of course you could get zapped like an ant under a magnifying glass too
papaglide
Cab on the D , no likey.....bubble on mower, me likey....a LOT!
