wingrider
Trying to figure out which motor I have
wingrider
I recently bought a Raider 10 8 speed that has had the engine changed to 12 horse motor. My problem is there is no
numbers on the motor to say what it is. How can I figure out what motor it is? I think the model number for the tractor
is 10360 and the serial number is 905302. The model is a guess because the numbers are very hard to read, but
the serial number is plain as day. I was just wandering if there is any noticeable difference between a 10 & 12 horse
Kolher motors.
Thanks for any help in this matter
Wingrider
diesel cowboy
Try looking at the block just above the crank on the pto side.  It might have the model number cast into it.  Some of the ones I've worked on had it and some didnt.  If it doesnt I think the only other way is to pull the head and measure the bore.  Not sure on that maybe someone else can say for certain.  The 10, 12, and 14 hp engines all used the same head gasket so its a little hard to tell otherwise without the tags.  Hope this helps.          Stewart
gwest_ca
You are likely correct on the 1-0360 model number. The serial 905302 is very close to 905294 which is also a model 1-0360.
Is your's decaled a Raider 10? In North America is was named a "10hp 8-speed" for 1973 - the no-name year.
Garry
wingrider
Thanks Gary
                      The decal on the side of the tank stand it says  Raider
        10
        8 Speed
                      it also has on the right side of motor right above the crankshaft a stamp saying + F  on my 1276 in the same location says K301
                       What I'm trying to figure out is this a transplant motor or did it come that way. I also found on another K301 on the aluminum
                        bearing plate some numbers stamped on the upper left of the plate.
            Thanks again for your help.
            Wingrider
Ihave a no name 10 HP motor but it has things that are different than this tractor????
r
Edited by wingrider
