Tankman 3,528 #1 Posted May 28, 2013 The 520 is runnin' like a clock, forget the "idiot" lights. Charging at 14-16 volts (per the gage). When I turn lights on, volt gage drops to 10-12 volts. Doesn't however seem to do anything. Should I investigate? Necessary PM needed? :smile: Share this post Link to post Share on other sites
woodchuckfarmer 333 #2 Posted June 1, 2013 mine dose the same thing.......ive had no problems with it Share this post Link to post Share on other sites
stevebo-(Moderator) 8,605 #3 Posted June 1, 2013 yup time to unload that boat anchor.. I will help you find a new home for it lol Share this post Link to post Share on other sites
Save Old Iron 1,573 #4 Posted June 1, 2013 tankman, check the battery voltage with a multimeter see if it matches the response of the tractor voltmeter Share this post Link to post Share on other sites
Tankman 3,528 #5 Posted June 1, 2013 tankman, check the battery voltage with a multimeter see if it matches the response of the tractor voltmeter What a novel idea! T will check it today. Thanks SOI! Share this post Link to post Share on other sites
Save Old Iron 1,573 #6 Posted June 1, 2013 i'm guessing the battery will not change by 2 volts under headlight load. If you use your multimeter to measure voltage present at the tractor voltmeter (any pink wire) and your multimeter reading agrees with the tractor voltmeter reading - then corrosion in the 25 amp fuse holder, ignition switch wiring and the 15 amp fuse holder would be the likely suspects. Share this post Link to post Share on other sites
WH nut 553 #7 Posted June 1, 2013 You mean to tell me those gauges arent just for looks? Share this post Link to post Share on other sites
