Motor Head110
Briggs 402707
Motor Head110
Does anyone know what the stock carb adjustments are on a 402707?
Also, does anyone have a manual for this motor?
Thanks!
WH nut
There is no stock adjustment, there are starting points and you fine tune from there. I would say 1.5 to 2 turns out on the high speed and 1.5 on the low speed will get it running. The you fine tune from there . High speed first then low speed to get a smooth idle
Motor Head110
funny thing... it looks to me like there is no idle? is there supposto be one
WH nut
Im not sure how old the motor is, but some carbs are sealed from the factory after they are set.  You may have to knock a plug out to get to the adjustment. Can you post a picture?
Motor Head110
The motor in question is off of a late 80's Simplicity 6516-H
