bo dawg 536 #1 Posted May 27, 2013 Trying to get this tiller hooked up that I just got, not sure what is the correct size of the spring that attaches from back of tractor to front of tiller. lenght/diameter/gauge? Appreciate any help from ya. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,757 #2 Posted May 27, 2013 4629 spring replaces 90106 Spring Extension 7.500" between the hooks, .220" wire, 1-1/2" coil OD, 5-1/2" coil length, 24-1/2 coils Garry Share this post Link to post Share on other sites
bo dawg 536 #3 Posted May 27, 2013 4629 spring replaces 90106 Spring Extension 7.500" between the hooks, .220" wire, 1-1/2" coil OD, 5-1/2" coil length, 24-1/2 coils Garry Thanks Gary, thats some info! Little confused though which isnt hard for me... 7-1/2" & 5-1/2" lenghts. Without seeing, so off the store rack the spring would be the 5-1/2" lenght as holding in the hand between the hooks? Then it will extend to 7-1/2" when installed on tractor? Thanx Bo Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,757 #4 Posted May 27, 2013 No - I believe there is 1" of hook on each end. I have never seen one except here http://www.wheelhorseforum.com/files/file/1361-snowthrower-lift-spring-assist-kit-8-4311-om-ipl-803954pdf/ Same spring as for the snowthrower lift assist. Garry 1 Share this post Link to post Share on other sites
