zeke83 2 #1 Posted May 21, 2013 Something must have happened to my selonoid from sitting during the winter, so until I had time to work on it, I used a jumper cable to go from the battery directly to the starter. This worked fine twice, but this week I had a problem. I started it up with the jumper and mowed for a half hour, then went to eat dinner. I came back out to start again but I could not get the starter to turn over. I hooked the cables up to my truck battery, and I still would not turn over. I turned the motor over by hand to make sure nothing was stuck. When jumping from the truck I did have the negative cable hooked to the battery so the circuit was complete and should have worked. Any ideas? I did try and tap on the starter housing with a hammer Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,528 #2 Posted May 21, 2013 This model did not originally have a solenoid. Has one been added? This B&S has a starter/generator for those that are not familiar with them. Manual with wiring diagram Garry Share this post Link to post Share on other sites
zeke83 2 #3 Posted May 21, 2013 Yeah the solenoid does not appear to be an oem part Would there be any reason that the starter would not turn over when putting a jumper on it?? Share this post Link to post Share on other sites
racin_ny 25 #5 Posted May 21, 2013 Starter brushes could be bad Share this post Link to post Share on other sites
WH nut 553 #6 Posted May 21, 2013 Time to open her up and do some exploritory Share this post Link to post Share on other sites
racin_ny 25 #7 Posted May 22, 2013 Be careful with the hammer. A guy brought a starter over for me to repair and the magnet had broken up and jammed the starter up. Obviously someone was hitting it with a hammer. Share this post Link to post Share on other sites
zeke83 2 #8 Posted May 23, 2013 The starter is a Delco-Remy model 1101695 SN OK21 Any new aftermarket replacements for this?? Thanks Share this post Link to post Share on other sites
zeke83 2 #9 Posted May 23, 2013 Another thing I noticed was when I used a pair of jumper cables on the starter, they would get real hot quickly and start to weld/stick to the positive terminal. I get a tiny bit of movment of the motor when I do this Share this post Link to post Share on other sites
WH nut 553 #10 Posted May 23, 2013 Open the starter up for a look see, you have something going on in there. Its drawing way to much juice Share this post Link to post Share on other sites
zeke83 2 #11 Posted May 23, 2013 I hope to dig into it tonight Where can I find replacement parts...all I can find is that the starter is obsolete...or a NOS for $250!! Share this post Link to post Share on other sites
zeke83 2 #12 Posted May 30, 2013 Well I finally got around to taking apart the starter. Everything looked fine with nothing broken. I blew it out with air, and cleaned up what I could with some sand paper then sparyed electrical cleaner on everything. The brushes looked fine, so I put it all back together and mounted it back in the tractor. I cleaned up all the exterior connections, then tried to use it with the belt not connected. I used jumper cables from my truck, as the battery on the tractor was weak. The pully would spin slow, and I could stop it with my hand. The jumper cable would also get very hot, and almost start to weld itself to the terminal on the starter. What could be wrong?? Thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,528 #13 Posted May 30, 2013 This old Kohler manual has a good section on the starter/generator. Any long established automotive electrical repair shop will be very familiar with these. Every GM had a similar unit up till about 1962-64. Garry Share this post Link to post Share on other sites
Save Old Iron 1,571 #14 Posted May 30, 2013 zeke, the armature probably has some shorted segments the armature can no longer produce the proper electrical "cadence" to keep the armature spinning if the armature windings look more blackish than copper colored, have the armature "growled" at the repair shop. Share this post Link to post Share on other sites
WH nut 553 #15 Posted May 31, 2013 If you cant find a shop with a growler, you can use an Ohm meter and check each segment of the commutator from segment to ground(shaft) 1 Share this post Link to post Share on other sites
Kelly 1,033 #16 Posted May 31, 2013 send me a PM, I think I have one of these starters in stock, but it might be a day or 2 before I can look my Daughter is graduating this weekend and we are very busy. Share this post Link to post Share on other sites
