tlcmbc
308-8 quits running
tlcmbc
When I mowed in the cooler temps I was able to mow the whole yard with no problems. It has gotten warmer and this weekend the problem came back . This happened last year also. What it does is starts and runs great for a while, then acts just like its ran out of gas. If I let it sit it will eventually start but will repeat the same thing. What does this sound like?
Fordiesel69
Is it a K181 or M8?
If magnum 8 I would suspect a bad magneto.
If a k181 the coil could be overheating to due an open condenser or the coil is just going bad.  Upon it stalling out, you may considre checking fuel output at the fuel pump.  Could be a vent problem with the gas cap.
skrusins
I had the same problem for 2 years, check cap, rebuilt fuel pump, reroute fuel line and installed filter.
The last thing I did was cleaned and readjusted the points. It has had any problems since.
