posifour11 723 #1 Posted May 16, 2013 I made a deal for my first round hood. I'll be picking it up next week and was wondering if it was short enough to fit in my pickup under the camper shell. Any ideas? Share this post Link to post Share on other sites
stevebo-(Moderator) 8,602 #2 Posted May 16, 2013 I would think that if you need to you can pull the front and/or rear wheels and it should fit. I do not have the measurements right now. If nobody else helps you with them, send me a pm and I can measure for you tomorrow. Share this post Link to post Share on other sites
rydogg 186 #3 Posted May 16, 2013 I just measured my 701 and it is 36 inches tall at its highest point which is the steering wheel. Share this post Link to post Share on other sites
bowtieguy 334 #4 Posted May 16, 2013 The answer is NO..........but it will fit in mine!!!.....i thought I got all the round noses in your neighborhood????? 1 Share this post Link to post Share on other sites
squonk 45,018 #5 Posted May 16, 2013 I used to have a Chevy Colorado with a cap and if I removed the steering wheel on my 704 it would just fit. Share this post Link to post Share on other sites
posifour11 723 #6 Posted May 16, 2013 Thanks guys. I have a mini truck and I only have 30 inches to work with. Guess I'll take the shell off. Not a huge deal. And Frank, this one is way out in KS. Three hours one way. Share this post Link to post Share on other sites
VinsRJ 723 #7 Posted May 16, 2013 Thanks guys. I have a mini truck and I only have 30 inches to work with. Guess I'll take the shell off. Not a huge deal. And Frank, this one is way out in KS. Three hours one way. Like Steve said just rank the front wheels or back wheels off... should slide right in. 1 Share this post Link to post Share on other sites
posifour11 723 #8 Posted May 16, 2013 Alright. I trust you guys. I'll take tools with me. Share this post Link to post Share on other sites
posifour11 723 #9 Posted May 21, 2013 Going to pick it up tomorrow. What size are the bolts for front and rear tires? Share this post Link to post Share on other sites
Jake Kuhn 1,592 #10 Posted May 21, 2013 Rears come off with a 5/8 socket. Fronts are held on with a snap ring or either a 9/16 socket. 1 Share this post Link to post Share on other sites
posifour11 723 #11 Posted May 21, 2013 Thanks Jake. I'll be sure to take the right tools. Share this post Link to post Share on other sites
bowtieguy 334 #12 Posted May 22, 2013 Remember....they still shoot horse thieves in KS....if you make it back alive then by law you have to check in with border patrol (KS/MO) and I'll check you for proper permits.....be aware that any suspicious cargo is subject to be held as evidence That's my story and I'm sticking to it!! .. 1 Share this post Link to post Share on other sites
posifour11 723 #13 Posted May 22, 2013 How about I promise you a picture and maybe a ride if I take it to Adrian? 1 Share this post Link to post Share on other sites
posifour11 723 #14 Posted May 22, 2013 She made it home. It needs work, but I have a round hood! I got the front wheels with it, but they need work to hold air. 3 Share this post Link to post Share on other sites
AMC RULES 37,252 #15 Posted May 22, 2013 Nice score. Did the engine come with it? Share this post Link to post Share on other sites
posifour11 723 #16 Posted May 22, 2013 Sadly, no engine. He tossed it because it had a broken rod. I have an old Clinton I hope to get running to put on it. 1 Share this post Link to post Share on other sites
Jake Kuhn 1,592 #17 Posted May 23, 2013 Looks pretty nice! Does it have the plastic dash like most 701's had or a newer style dash? 1 Share this post Link to post Share on other sites
rydogg 186 #18 Posted May 23, 2013 Looks pretty nice! Does it have the plastic dash like most 701's had or a newer style dash? Check out the third picture...it looks like someone put on a 702 dash. Share this post Link to post Share on other sites
rydogg 186 #19 Posted May 23, 2013 Looks like a good little restoration project. If you get near Minnesota I have a couple 7hp k161 kohlers I will probably part with at least one of them I could ship but the cost is a little crazy for these cast iron engines. Blue engine pictured below would be great for a 701 since it has the double pulley starter setup. 1 Share this post Link to post Share on other sites
Kevbo 81 #20 Posted May 23, 2013 Wow! The paint looks really nice on that! Is that original? Share this post Link to post Share on other sites
posifour11 723 #21 Posted May 23, 2013 Jake, It has a wood grain dash. Don't know what they came with. Ryan, I'll have to save my nickels to get one that pretty. Kevin, not original paint. PO painted it. A ten footer at best. Hammer marks and such with dust in the paint. Hopefully, I can restore it to its former glory. Share this post Link to post Share on other sites
posifour11 723 #22 Posted May 24, 2013 I was wrong. The dash is cast metal covered in a white sticker with black grid lines. Share this post Link to post Share on other sites
rydogg 186 #23 Posted May 24, 2013 I was wrong. The dash is cast metal covered in a white sticker with black grid lines. It is held on with 4 screws and was used in 1962 on 502 552 702 and lawn ranger. You can order the correct 701 dash from the vendors section and put it on in place of the cast one also the correct split key ignition switch can be found on ebay they were used on massey tractors to20 to30 etc, the push button starter switch on mine is from a snapper rear engine rider, and the correct looking throttle and choke cables can be found on ebay they were used in early Jeeps. Here is a picture of the one I ordered from ebay for around $20 to my door. 1 Share this post Link to post Share on other sites
posifour11 723 #24 Posted May 24, 2013 Maybe I should check it over some more tomorrow. It doesn't have the belt guard and I took his word that it was a 701. Didn't even look for a tag. Share this post Link to post Share on other sites
rydogg 186 #25 Posted May 24, 2013 A few observations....hood is from a 701, foot pads 701 also, the shifter with the extra bend was used in 1962 since the 702 had the option for a hy2 hydraulic lift pump therefor they had an extra bend to fit the pump, mower deck is 701 since the wheels are "hidden" within the deck. A lot of parts from the 701 and 702 are the same such as the front axle, gas tank is 1 piece with a bolted on cover, clutch/brake pedal is smaller and more rounded than the 1963 and up models. I believe you have a 702 with some 701 parts on it or the other way around. Here is a picture of mine you can see that the shifter has only on bend. 1 Share this post Link to post Share on other sites
