papaglide 542 #1 Posted May 14, 2013 Might be getting a C-195 but he 60" deck just seems to big for my yard. Would a "normal" 42" SD or 48" SD deck fit and operate on a C-195? Would the belts be different or the same as the belts I use on my 416? Share this post Link to post Share on other sites
Fordiesel69 274 #2 Posted May 14, 2013 I beleive the mule drive is the same but the belt going from the PTO to the deck might be different. The brackets are all the same to mount the deck. I was going to go the other way, 42" to 60". PM me if you are interested in a trade + some cash. Share this post Link to post Share on other sites
baerpath 517 #3 Posted May 14, 2013 A C195 mule is different than other C's only has one pulley the other is frame mounted. You can change things around to make a 48 fit, not sure if a 42 would work though Share this post Link to post Share on other sites
papaglide 542 #4 Posted May 14, 2013 Thanks Duane. How involved would it be to use a 48? Is the 195 a pretty manueverable tractor with the 60? Share this post Link to post Share on other sites
