cheesegrader 436 #1 Posted May 14, 2013 I have a '97 79361 2-stage snowblower with a leak in the gearbox between the augers. I hoped it was just the plug, but no luck. It looks like it is coming through the gasket between the two halves of the gearbox. This looks like an easy fix with the $15 toro replacement gasket. Is there anything else I should replace while I have it apart? Oil seals to the augers? Any voices of experience out there? I would hate to get it apart only to find that I neglected to deal with something simple that will cause me headaches in the middle of a blizzard next winter. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,342 #2 Posted May 14, 2013 Peerless parts list Garry Share this post Link to post Share on other sites
scraper 4 #3 Posted May 14, 2013 Yes, the gearbox has 3 oil seals that should be replaced every 10 or 12 seasons in my opinion as regular maintainance items as well as the two bearings at both ends of that shaft. While you have it apart, just take a peak at all the washers and thrust washers on the input shaft. Go to partstree and printout the view of the gearbox first if you want to take it apart for a better look. Best to replace them now and not in the winter time. I completely rebuilt my unit last year, and it works great. One last thing, check the seals and gaskets on the right angle gearbox too see if they are leaking. If you have never replaced them, now would be a good time as they always end up leaking as well. 1 Share this post Link to post Share on other sites
RMCIII 840 #4 Posted May 14, 2013 Looked throuhg 4 pages of posts, so instead of starting a new one, thought I would tag onto this. My 42" appears to have a bearing going out, or already out/ It is on the primary pully that is driven by the belt. 2 questions: How difficult is it to replace that bearing Is it better to just take the entire shaft off and replace both the belt pully bearing and the chairn drive bearing all at once > what is involved with this? Rob Share this post Link to post Share on other sites
scraper 4 #5 Posted May 14, 2013 I have never worked on that model. I can tell you that all bearings and bushings on snowthrowers, including walkbehinds, are regular maintanance items and should be replaced. Share this post Link to post Share on other sites
cheesegrader 436 #6 Posted May 14, 2013 OK, I see the seals for the right angle gear box, and I see the seals to the augers on the front gear box, but I don't see a seal on the back of the front gear box for the impeller shaft. Is it labeled as one of the washers? Share this post Link to post Share on other sites
scraper 4 #7 Posted May 15, 2013 Go to partstree, type in 79361 where it says (enter model here),it will be number 4 on the parts list, number 237-87. The description of it just says seal, not oil seal,but when it is worn out it will leak oil as well. Share this post Link to post Share on other sites
cheesegrader 436 #8 Posted May 15, 2013 Part #4 Quad Ring. Got it. Thanks! Share this post Link to post Share on other sites
Ike 93 #9 Posted September 9, 2019 I know it is an old thread but I picked up a mint 44” 79361 that looks like it has been rarely if ever used. I noticed when I just ran the snowblower just to test it out it left a small drip about the size of a quarter. Any words of wisdom from those who replaced that gasket that is leaking on the gear box. Also, anybody try thicker oil ? Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #10 Posted September 9, 2019 44 minutes ago, Ike said: I know it is an old thread but I picked up a mint 44” 79361 that looks like it has been rarely if ever used. I noticed when I just ran the snowblower just to test it out it left a small drip about the size of a quarter. Any words of wisdom from those who replaced that gasket that is leaking on the gear box. Also, anybody try thicker oil ? I haven't tried this but another member has stated that they uses this instead of gear oil ... https://www.amazon.com/Lubriplate-L0034-094-Motor-Assembly-Grease/dp/B000HZJFE0 ... When I rebuilt my 2stage it wasn't the gearbox gasket that leaked it was the "quad ring" seals on the at her and impeller shafts that was leaking even the new O.E. replacement s weren't the correct size IMHO but where I worked at had what I considered the correct size and after 3-4 seasons NO leaks as of yet. Share this post Link to post Share on other sites
Ike 93 #11 Posted September 10, 2019 I am willing to try anything to avoid splitting that gear box. Thanks for the suggestion! Share this post Link to post Share on other sites
lynnmor 8,891 #12 Posted September 10, 2019 Mine always did drip some oil even after gasket and seal replacement. Since the chain should be lubricated often, and that will drip, I just put cardboard or newspapers under the entire dripping area. Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #13 Posted September 10, 2019 6 minutes ago, Ike said: I am willing to try anything to avoid splitting that gear box. Thanks for the suggestion! @wallfish was it you that used the lubriplate grease? Anyways I'm with you on not splitting the gearbox... The only reason I did the impeller was bent from the PO and had sat outside its entire life Share this post Link to post Share on other sites
Ike 93 #14 Posted September 10, 2019 Here is the front view. I just picked it up. Thinking I might just try it for a season before I go nuts with it. 2 Share this post Link to post Share on other sites
Ike 93 #15 Posted September 10, 2019 35 minutes ago, WVHillbilly520H said: @wallfish was it you that used the lubriplate grease? Anyways I'm with you on not splitting the gearbox... The only reason I did the impeller was bent from the PO and had sat outside its entire life That does not look like the same blower! Nice restoration! 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #16 Posted September 10, 2019 9 minutes ago, Ike said: Here is the front view. I just picked it up. Thinking I might just try it for a season before I go nuts with it. Looks like the quad rings seals are your leaks... If it were me I would just drain out the remaining oil and add the assembly lube grease, as your blower does look nearly unused. Share this post Link to post Share on other sites
Ike 93 #17 Posted September 10, 2019 Any suggestion on how drain? Plastic tubing? Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #18 Posted September 10, 2019 8 hours ago, Ike said: Any suggestion on how drain? Plastic tubing? Unfortunately that would require unhitching from the tractor removing fill plug then "upending" the blower over a shallow pan unless someone else chimes in with a better plan of attack? Share this post Link to post Share on other sites
peter lena 9,938 #19 Posted September 10, 2019 just an idea , but how about the j/d corn cob grease ? its made for that type of gearing drive. if you have a lubricant that will not run out , why not try it ? pete 1 Share this post Link to post Share on other sites
Ike 93 #21 Posted September 11, 2019 Great video and thanks all for the feedback! Share this post Link to post Share on other sites
