wh1257 226 #1 Posted May 11, 2013 hello as you know I have a wheel horse 753 once I took him again to make after the temperature of the engine on a ride he started acting weird and he fell silent I made the carburetor clean, but was doing during cold start will he run until he is hot but warm once he falls silent again does anyone know what this could beit is a 7 hp kohler engine usa Share this post Link to post Share on other sites
KATO 115 #2 Posted May 11, 2013 First thing i would suspect is the coil. Does it have spark when hot ??? Share this post Link to post Share on other sites
WH nut 553 #3 Posted May 11, 2013 Could be a bad condensor also Share this post Link to post Share on other sites
wh1257 226 #4 Posted May 11, 2013 First thing i would suspect is the coil. Does it have spark when hot ??? yes if it is rotated hot he wants halt but I can not let him run on choke Share this post Link to post Share on other sites
puddlejumper 67 #5 Posted May 13, 2013 The fuel pump could be failing under heat also. You may try bypassing pump and gravity feed directly to carb Share this post Link to post Share on other sites
