welderman85 53 #1 Posted May 11, 2013 hi i just picked up new tires for my lt 1136 i bought 15x6 but when i went to pull the old tires off i noticed the stock tires were 13" will the two inchs make a differance in deck height or should i get the correct tires thank you Share this post Link to post Share on other sites
Don1977 606 #2 Posted May 11, 2013 It will only make a one inch difference in the height of the tractor at the front. I would use them don't think it will make much difference. If they are like a lot of tires we've seen lately they don't measure a full 15" anyway. Share this post Link to post Share on other sites
Save Old Iron 1,573 #3 Posted May 11, 2013 You may (probably will) end up with a floating mower deck that is significantly altered in its front to back tilt. You may need to raise the rear of the mower deck in relation to the front in order to maintain the correct cut. The LT's may or may not have that amount of adjustment available on the mower deck. Share this post Link to post Share on other sites
