tractorbeast 27 #1 Posted May 8, 2013 Would someone with C-195( or any wheel horse owner) have info on the wheels for a C-195. Are there wider rims available with the 6 lug pattern. Was this size used on any trucks, or just tractors? I have read on this forum that Case used this size. Share this post Link to post Share on other sites
Hodge71 665 #2 Posted May 8, 2013 I believe that they are the same as the 15s found on the D series machines Share this post Link to post Share on other sites
baerpath 517 #3 Posted May 8, 2013 Bolen's large frame, Ford 195's/Jacobson 1650's,MTD 990's are a few that used the same size. Some farm impliments use the same pattern with wider 15 inch rims. I've been told Chevy truck 6 hole rims would fit but have not tried it to know for sure Share this post Link to post Share on other sites
Don1977 605 #4 Posted May 8, 2013 Bolen's large frame, Ford 195's/Jacobson 1650's,MTD 990's are a few that used the same size. Some farm impliments use the same pattern with wider 15 inch rims. I've been told Chevy truck 6 hole rims would fit but have not tried it to know for sure Most MTD 990's have four lug rear wheels I have seen one with five don't know if it was factory. Share this post Link to post Share on other sites
baerpath 517 #5 Posted May 9, 2013 My assumption, mine had six lug 9.50x15 Firestone bar treads. I also bought a D that had five lug rims. As long as the axle is the right size I guess you can swap them out. Share this post Link to post Share on other sites
Wheelhorse860 1 #6 Posted May 9, 2013 i got some26x12x12 on my d180, 6 lug, its awesome Share this post Link to post Share on other sites
