farmallm1 1 #1 Posted May 7, 2013 I have a 416 with a Kohler 16 Hp it will run good at low idle and good to 3/4 speed then will start to boog down choke will not help. it will start sputting gas out the carb at higher Rpm I have changed gas and fuel line filter plug removed carb and soked in pail of cleaner run air in all pasages all clear still spitting gas out carb.removed head and cleaned carbon and removed valves and lapped them all ok no worped valve carb adjustments make no diffrence lean or rich it has 2 adjustment screws what am I missing Thanks for your help Mark Share this post Link to post Share on other sites
Callen 64 #2 Posted May 7, 2013 Is it a Magnum or k series? Share this post Link to post Share on other sites
WH nut 553 #3 Posted May 7, 2013 Pull the muffler off and see how she runs. 1 Share this post Link to post Share on other sites
farmallm1 1 #4 Posted May 7, 2013 Magnum 16 Hp can the float sink coil going bad ???? Share this post Link to post Share on other sites
WH nut 553 #5 Posted May 7, 2013 See post above, there is a reason and sequence for trouble shooting What you are describing with the way it bogs and spits gas at full throttle tells me the exhaust is plugged Share this post Link to post Share on other sites
farmallm1 1 #6 Posted May 8, 2013 Got to work on it some today removed mufler and it is running very well maybe the best that it has ever ran Can you burn out the mufler like 2 cycle over camp fire I will try it and post back if it dont work what is the best place to get new one??? 1 Share this post Link to post Share on other sites
tunahead72 2,600 #7 Posted May 8, 2013 Before you do anything too drastic, check the muffler carefully for anything that might be plugging it up. I once had a mud dauber nest inside the muffler of a 2-cycle tiller engine, wouldn't run for more than a minute or so before it would die. Poked out the nest with a paper clip, and it ran like new again. Share this post Link to post Share on other sites
WH nut 553 #8 Posted May 8, 2013 If you dont mind the looks and a little more noise just put the salt shaker type on it and run. Share this post Link to post Share on other sites
