Fordiesel69 271 #1 Posted May 5, 2013 The ACR spring was broke, so I ripped it off the cam so it would not fly off and damage the engine upon rebuild. The starter did not have any problem before turing it over. I was wondering if the counter weight would flap around and get damaged. Can this spring be sourced or does the cam need to be replaced? Share this post Link to post Share on other sites
MarkPalmer 81 #2 Posted May 6, 2013 It should be fine without the spring. It just helps the flyweight come back to low speed position when the engine is stopped, and doesn't necessarily render the ACR ineffective. -Mark- Share this post Link to post Share on other sites
oldredrider 2,553 #3 Posted May 6, 2013 The last time I checked (bout a month ago) the spring is still available from Kohler. However, the K series cam is not. Share this post Link to post Share on other sites
Fordiesel69 271 #4 Posted May 6, 2013 So to be clear, I don't need to worry about it..... Like I said the starter was able to handle it just fine. I would buy one but my local shop did not have on and can't for another week. Share this post Link to post Share on other sites
MarkPalmer 81 #5 Posted May 6, 2013 The springs assist the weights to move inward when the engine is shut down to actuate the ACR. Not having them won't necessarily stop the ACR from working, but they make it easier for it to work. Any of the K engines with a gear driven starter (and a good battery) don't really benefit much from the ACR, you might not even notice if it's actuating or not when cranking the engine. I've even built K181's that used starter generators using the non-ACR spark advance cam, and you would be hard pressed to tell the difference in the cams. -Mark- Share this post Link to post Share on other sites
Fordiesel69 271 #6 Posted May 6, 2013 Excellent, less work for me then. Hope to have it buttoned up by wed and have it mounted by thurs. Share this post Link to post Share on other sites
