fireman 1,022 #1 Posted May 5, 2013 (edited) Headed out at 6:00am this morning to go pick up the 1054 from Duane. It's a 3 hour ride each way and had to get back in time for dinner with all my family. Also brought home some parts that Docwheelhorse bought from him. The 1054 is great condition. Looks all original except for the seat. Even has a single rear red light on a plate which looks original bought not sure. Gave it a very quick bath as a had to go to dinner with the entire family: Edited May 5, 2013 by fireman 2 Share this post Link to post Share on other sites
Jake Kuhn 1,581 #2 Posted May 5, 2013 Very nice jeff! I really like the look of the 1054s and 953's. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,590 #3 Posted May 5, 2013 A few things that I see wrong with it already..... (tractor police) 1- Rear tires and rims 2- Entire pto set up 3- Front grill I am more than willing to help you find a new home for those itemes Looks very nice for sure! Share this post Link to post Share on other sites
KC9KAS 4,744 #4 Posted May 5, 2013 Nice looking GT! Share this post Link to post Share on other sites
Ken B 3,202 #5 Posted May 6, 2013 Looks real nice Jeff. There is one in Ansonia I might take a look at. Share this post Link to post Share on other sites
fireman 1,022 #6 Posted May 6, 2013 Got back from dinner and just had to take it for a cruise before I locked it away in the trailer (don't have anymore inside storage available so the enclosed trailer will be it's new home). I just love the way it drives. Hydro lift works great. Tuesday I will change the oil, replace the spark plug, fuel lines and pull the carb and give it a quick rebuild. The starter/generator has a loud bearing so I pull that apart and replace those and the brushes while I'm at it. Give her a quick degreasing and she should be good to go. I also contacted Glen Pettit and am getting his reproduction front and rear lenses for it also. Share this post Link to post Share on other sites
neil 2,410 #7 Posted May 6, 2013 well worth the 6 hour trip, I would love to own one of these , ithink they are a great looking GT , You just need to look out for an original type seat . Really Nice Tractor great buy Share this post Link to post Share on other sites
Wheel-N-It 2,976 #8 Posted May 6, 2013 Good looking tractor. Its a keeper for sure. Share this post Link to post Share on other sites
fireman 1,022 #9 Posted May 11, 2013 (edited) Had a marathon day today working on the 1054. It needed a bit more work than I thought. The wiring was an abortion and I replaced a bunch of wires and cleaned it up so that all the connections are now solid. I had to rebuild the starter/generator as it had a loud bearing. The bearings were actually ok so I cleaned them in the parts cleaned tank and repacked them. The brushed were actually fine. Sanded down all the parts and primed and painted them. It's now back together and on the tractor. I had to pull the gas tank out as it was full of sand and sediment. Only problem was on the 1054 then seat and fender pan are welded to the frame and the tank is mounted between that and the transmission. Had to jack up the rear of the tractor and put stands under the back portion of the frame then unbolt the rear end and let it down so I could pull out the gas tank. The inside of the tank is remarkably clean with no rust except around the fill opening. Rebuilt the tank mounted glass fuel bowl cleaner and re-installed all of that. Next the carb came off and pulled that all apart. There was a lot of scale inside so I soaked the body in the parts cleaner and headed out to get a re-build kit. Luckily the local NAPA had a actual Kohler kit in stock. Came back home and finished cleaning all the parts and re-assembled it with the new parts. Put the carb back on and ran all new fuel line with an inline filter. Pulled off the side covers so I cold adjust the clutch and brake. There were 3 broken bolts in the mounting tabs so took advantage of being in there and got those removed. At this point spayed it down with degreaser and let it sit for a few minutes, then took the pressure washer to it and removed all the old grease and grime. All in all spent about 8 hours on it today. All that work and in a few months I'm still gonna completely tear it apart and give it a proper restoration! I must be crazy! At least it now runs good and is ready to hit the summer shows and cruise around on with no worries of any problems. Edited May 11, 2013 by fireman Share this post Link to post Share on other sites
welderman85 53 #10 Posted May 11, 2013 great looking buy Share this post Link to post Share on other sites
Kevbo 81 #11 Posted May 11, 2013 Very nice! What models besides this maintain that style hood/front? I would like to add that style to my collection someday! Looks great bud! Share this post Link to post Share on other sites
fireman 1,022 #12 Posted May 11, 2013 The 953, 1054 and GT14 have this style front end. Share this post Link to post Share on other sites
Lane Ranger 11,634 #13 Posted May 11, 2013 Great looking 1054 ! Love the way those tractors operate! Share this post Link to post Share on other sites
papaglide 542 #14 Posted May 11, 2013 Nice looking tractor! Gear drive with a hydraulic lift is my ultimate combo.....maybe someday I can add one to the fleet. Share this post Link to post Share on other sites
VinsRJ 723 #15 Posted May 11, 2013 Looks like a great tractor Jeff! Share this post Link to post Share on other sites
