Marv 983 #1 Posted May 3, 2013 Battery trays are a problem for me. What is the cure for the problem. How do you treat them? Marvfin Share this post Link to post Share on other sites
rmaynard 16,341 #2 Posted May 3, 2013 What is the problem that you are having? Share this post Link to post Share on other sites
KATO 115 #3 Posted May 3, 2013 (edited) If corrosion is the issue ??? I neutralize any acid with baking soda and water then media blast and repaint. Then i put one of these under the battery... http://www.amazon.com/The-Battery-Mat-Acid-Neutralizing/dp/B002PCU1U0 Edited May 3, 2013 by KATO 1 Share this post Link to post Share on other sites
squonk 43,894 #4 Posted May 3, 2013 I cut small piece of rubber like a mat to put on mine. Share this post Link to post Share on other sites
Lane Ranger 11,411 #5 Posted May 3, 2013 I use a 1/4 thick foam pad cut to the size of the battery tray. The real dense kind that defects moisture. I use this in the RJ's and other Wheel Tractors with a work/tool tray under the spring seats too! Share this post Link to post Share on other sites
big mike 13 #6 Posted May 3, 2013 I use brush on bed liner.....works great and looks good. Share this post Link to post Share on other sites
Pollack Pete 2,273 #7 Posted May 3, 2013 I remove the battery tray,beadblast it,then paint it with POR-15 paint.They NEVER rust again. 1 Share this post Link to post Share on other sites
Hodge71 665 #8 Posted May 3, 2013 Works absolutely amazing!!! Share this post Link to post Share on other sites
squonk 43,894 #10 Posted May 4, 2013 I like the rubber. Absorbs the vibes! Share this post Link to post Share on other sites
bitten 134 #11 Posted May 5, 2013 Go with a sealed battery? Share this post Link to post Share on other sites
bo dawg 518 #12 Posted May 5, 2013 I just use the plastic tray liners that were intended for this. Works fine for me. Share this post Link to post Share on other sites
Marv 983 #13 Posted May 5, 2013 Thanks everybody, Problem is usually corrosion. Even though I clean with Baking soda and thoroughly scrub the metal and repaint, over time rust/corrosion comes back. I had read about the POR 15. My understanding is the shelf life somewhat short once opened. Product is quite expensive for that little bit. I have a mower deck that I have started to redo. I might just wait until it is ready and get enough to do it and do battery trays then. I never tried the rubber or foam pads, might try that. The anti corrosion pads sound interesting too. I have a couple tractors with the plastic trays but they are cracked. Marvin 1 Share this post Link to post Share on other sites
squonk 43,894 #14 Posted May 5, 2013 I was out mowing today and noticed the battery bouncing around. Wing nuts worked loose. Share this post Link to post Share on other sites
