Countdown To Christmas!
sparky6398
Lawn Vac Info Needed..
sparky6398
I picked up a WH PTO driven lawn vac to put on my Auto 14. I know the Vac Pack mounts on the rear quick attach mount and also on the draw bar. How does it get it's power, from the Hydro input with another pulley added or from the engine PTO? If it is belted to the engine, how is it routed, I didn't get any kind of a mule drive or belt guard with it. Here are a couple photos of it along with the ID tag info on the Vac frame. Any manuals of service bulletins you might have, I would really appreciate. Thanks
post-7529-0-90060500-1367431134_thumb.jppost-7529-0-68087200-1367431132_thumb.jppost-7529-0-23429500-1367431299_thumb.jp
gwest_ca
This likely does not apply to what you have
Have never seen anything else on this model.
Garry
gwest_ca
This is a 1977 model and looks to be going in the correct direction to me.
Garry
Don1977
Garry
Your right, I was look at it wrong, it can be driven off the Transmission with a double pulley.
sparky6398
Thank you Gary, I appreciate the help!! :thumbs:
dsholler
Post some video of that thing working when you can.
sparky6398
I will, if I ever get it working.
gwest_ca
Here is an older manual that may help
Garry
sparky6398
Thanks Gary, That manual explained it a whole lot better.
sparky6398
Started mounting the vac system on my Auto14 today. Put the rear quick attach on the differential. I moved the right side running board out to allow the PTO belt to go from the PTO clutch to the fan drive. I have to make up a couple idler pulleys to allow the belt to miss the axle. I will also have to make up a belt guard that goes next to the Transaxle belt guard and fill the gap at the foot rest.
post-7529-0-39512200-1368459879.jpgpost-7529-0-79763300-1368459881.jpgpost-7529-0-59719000-1368459878.jpgpost-7529-0-14384400-1368459880.jpgpost-7529-0-00170600-1368459881.jpg
sparky6398
I don't know why the pictures aren't showing, I thought I uploaded them right??
** I got it fixed, I uploaded the photos a BMP's instead of JPEG's. :confusion-questionmarks:
Edited by sparky6398
rwilson
I so want one of them!!
bk-scouter
Sparky, I sent you a PM
-BK
