sparky6398 2 #1 Posted May 1, 2013 I picked up a WH PTO driven lawn vac to put on my Auto 14. I know the Vac Pack mounts on the rear quick attach mount and also on the draw bar. How does it get it's power, from the Hydro input with another pulley added or from the engine PTO? If it is belted to the engine, how is it routed, I didn't get any kind of a mule drive or belt guard with it. Here are a couple photos of it along with the ID tag info on the Vac frame. Any manuals of service bulletins you might have, I would really appreciate. Thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,441 #2 Posted May 1, 2013 This likely does not apply to what you have Have never seen anything else on this model. Garry 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,441 #3 Posted May 1, 2013 This is a 1977 model and looks to be going in the correct direction to me. Garry 2 Share this post Link to post Share on other sites
Don1977 605 #4 Posted May 1, 2013 This is a 1977 model and looks to be going in the correct direction to me. Garry Your right, I was look at it wrong, it can be driven off the Transmission with a double pulley. 1 Share this post Link to post Share on other sites
sparky6398 2 #5 Posted May 2, 2013 Thank you Gary, I appreciate the help!! Share this post Link to post Share on other sites
dsholler 54 #6 Posted May 2, 2013 Post some video of that thing working when you can. 1 Share this post Link to post Share on other sites
sparky6398 2 #7 Posted May 2, 2013 I will, if I ever get it working. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,441 #8 Posted May 2, 2013 Here is an older manual that may help Garry 1 Share this post Link to post Share on other sites
sparky6398 2 #9 Posted May 2, 2013 Thanks Gary, That manual explained it a whole lot better. Share this post Link to post Share on other sites
sparky6398 2 #10 Posted May 13, 2013 Started mounting the vac system on my Auto14 today. Put the rear quick attach on the differential. I moved the right side running board out to allow the PTO belt to go from the PTO clutch to the fan drive. I have to make up a couple idler pulleys to allow the belt to miss the axle. I will also have to make up a belt guard that goes next to the Transaxle belt guard and fill the gap at the foot rest. Share this post Link to post Share on other sites
sparky6398 2 #11 Posted May 13, 2013 (edited) I don't know why the pictures aren't showing, I thought I uploaded them right?? ** I got it fixed, I uploaded the photos a BMP's instead of JPEG's. Edited May 13, 2013 by sparky6398 Share this post Link to post Share on other sites
rwilson 128 #12 Posted May 14, 2013 I so want one of them!! Share this post Link to post Share on other sites
bk-scouter 93 #13 Posted May 14, 2013 Sparky, I sent you a PM -BK Share this post Link to post Share on other sites
