redidbull 54 #1 Posted April 30, 2013 I have a pull start Horse that I removed the carb for cleaning/rebuilding. I took this pic but I should have taken a few more because I have some questions. How does the plate hook to the throttle? Also there looks to be a spring in the right hand side of the pic but I can not find a spring. It has been a while since I took this all apart. It there somewhere where there may be an exploded view of this? Thanks. Jim Share this post Link to post Share on other sites
SousaKerry 503 #2 Posted April 30, 2013 What is this on? Does not look Wheel Horse Tiller maybe?? There are some good illustrations in the service manual located in the manuals section Share this post Link to post Share on other sites
redidbull 54 #3 Posted April 30, 2013 What is this on? Does not look Wheel Horse Tiller maybe?? There are some good illustrations in the service manual located in the manuals section It is on this. Thanks. Jim Share this post Link to post Share on other sites
SousaKerry 503 #4 Posted April 30, 2013 Oh Ok, never played with a vertical shaft Techy other then an odd push mower or two. I will defer to another Ex-Spurt. Remember an EX is a has been and a Spurt is a drip under pressure! Share this post Link to post Share on other sites
MarkPalmer 81 #5 Posted April 30, 2013 It's been a long time since I fiddled with a Tec-crum-seh of that style, but I think it goes like this- there should be a rod with a spring that goes from the arm on the throttle cable connection plate to the governor arm, then a second rod from the governor arm (no spring) that goes to the carb throttle shaft. -Mark- Share this post Link to post Share on other sites
redidbull 54 #6 Posted May 1, 2013 Thank you. I am missing something. I need to really look at it against the pictures and your advice. Jim Share this post Link to post Share on other sites
redidbull 54 #7 Posted May 1, 2013 Continue my search for answers I finally found this. It may help someone else down the line. Thanks for the help. Jim http://www.lawnsite.com/showthread.php?t=109444&page=1 Share this post Link to post Share on other sites
