shangac 0 #1 Posted April 29, 2013 I have a 1976 B-80 with the 36" deck... does any know if a larger deck is a direct fit? Thank you, Share this post Link to post Share on other sites
varosd 1,185 #2 Posted April 29, 2013 The 42 RD and SD and the 48 SD will all fit, but our much loved 8 Hp Kohlers are a little bit small to spin them! I ended up just getting a bigger tractor with the 48 SD and I also pull Roxy-Bonner gang reels for a 60 inch cut. Share this post Link to post Share on other sites
shangac 0 #3 Posted April 29, 2013 OK thanks for the info. I use my tractor mainly for yard cleanup with a trailer, de-thatching, etc. I mow mainly with a commercial walk-behind but I'd love to get rid of that damn thing and just use the B-80 to mow. Share this post Link to post Share on other sites
Fordiesel69 215 #4 Posted May 1, 2013 I tried a 42" side on my B-80 that I used to own. It was able to spin it, but cutting grass required 1st gear. The 36 side is about right for the application. On the flip side of things, you will wear out the 8HP very quick. They are great engines when used properly, but when overworked they are not as durable as the big block. I never had a camera capable of video back then or I would have loved to watch it again today. I remember it was really working hard. 1 Share this post Link to post Share on other sites
B-100 Dan 7 #5 Posted May 2, 2013 Any 36" 42" or 48" will fit, but I think that 8 horse, as good as they are would end up with its tounge hangin out so to speak. I would not go above a 36" deck with an 8 horse motor. I had a 8 horse with 36" RD deck for quite a few years, worked well. Share this post Link to post Share on other sites
