pgannon95
Interchanable mower deck
pgannon95
can i put a b-115 mower deck on a c-120?
Don1977
No, look at your other post.
WH nut
I dont beleive you can. I would have to reseach to make sure.
WH854
You do know a B-115 tractor is a vertical shaft lawn tractor and a C-120 is a horizontal shaft garden tractor! I don't think it will hook up at all that's my 02cents. :thumbs:  :WRS:  Chas
WH nut
Im not sure if the shell is the same, if it is you can take all the mounting hardware of a c series and put on a B
puddlejumper
Sounds like you need a 36 or 37 inch deck from a b80 or a 308. place a wanted ad in the classifides somebody in your area may have one. The one I have from a 308 is the hex belt so you would have to change a pulley in your mule drive for that style but it would work.
