Kevbo 81 #1 Posted April 25, 2013 I am soon going to need to order a belt to attach my 417-8 to my rear tiller. Anyone know the size I need or part number? Thanks guys! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,012 #2 Posted April 25, 2013 Listed for the 1984 07-36TL02 and 1984-1989 07-36TL03 Toro 110265 Replaces 103635 and 107680 [HAx141"] Garry Share this post Link to post Share on other sites
wh79d160 52 #3 Posted May 10, 2013 Garry , Is that a "B" series (21/32) or a 5L (5/8). X 141" belt. Not sure what the HA means. The one that came w/my tiller is a B138 & it's too short. Also, my idler didn't come w/the tentioner spring. Have any idea how long that is supposed to be? Thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,012 #4 Posted May 11, 2013 An HA belt is 1/2" wide. It has been suggested a Gates or Napa 6652BR may work 1/2"x139-5/8" A B138 belt is an industrial belt 141" long but being 5/8" wide it will be too short in1/2" pulleys. The 6135 spring 3-5/16" between hooks, coil 5/8" diameter 2-3/8" long, 34 coils of .070" wire Garry Share this post Link to post Share on other sites
wh79d160 52 #5 Posted May 11, 2013 Garry, thanks for the Information. I'm off to find everything I need in the morning. One last thing. Do you have any idea the capacity of the 90 weight gear lube in the case of the tiller ? it has a plug on the top and the bottom side. Thanks again Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,012 #6 Posted May 11, 2013 A 1992 manual lists the refill capacity as 1 quart (.94 liter) Garry Share this post Link to post Share on other sites
wh79d160 52 #7 Posted May 11, 2013 Mine is a ??-36TL01. I think it's a late 70's.I got an instruction manual & parts list from Tyson,shubox lover, but it didn't say anything about capacity. Share this post Link to post Share on other sites
Kevbo 81 #8 Posted May 11, 2013 1 qt indeed! I bought Mobil 1 75W-140 to put in mine. Make sure the tiller is level when you drain and add. Share this post Link to post Share on other sites
jsp_333 286 #9 Posted August 27, 2013 Kevin My tiller {07-36tl01} came off a c-175 and the belt it came with is also too short to go on my 414-8. It measures approx 137.5 outside. Got a gates belt guy nearby and saw Garry's comment "It has been suggested a Gates or Napa 6652BR may work 1/2"x139-5/8". Also noticed you have the same set up as me a 414-8 and tiller. What belt do you use on your 414? Was wondering how your situation resolved itself with the 417?. cheers, john Share this post Link to post Share on other sites
wh79d160 52 #10 Posted August 27, 2013 I used a Rotary part# 12-12461. It is 1/2x141.1 & works great on my 417. Good luck Share this post Link to post Share on other sites
