carlsbarn2
Clutch conversion
carlsbarn2
Does anyone know approx. cost of converting to electric PTO ?
chrisd200(inactive)
You can buy a cheap electric pto for $175 - $200 range. Heavier duty ones run around the $300 and up range.
JUSS10
You can search for a used one. A lot of other big name tractors run them. I've seen them for 50-75. May need to fab up a special mount for it.
billysbarn
you need one i have 2
Hodge71
A lot of it has to do with what you're looking to convert. If its a C series it will be at least 100 bucks plus shipping and you will need to rewire the harness. If its a 200 series it should be cheaper as they are more readily available
bowtiebutler956
 Why do you want to convert to electric? The old clutch type :wh: PTO's seem very rugged to me. Just curious.
Matt :flags-texas:
Trouty56
I wouldn't mind one on the old Charger like the Electra did instead of the old side to side manual type.....
i967mustang
I took one off of my Charger 12 Plow tractor because it wasn't going to be used. I swapped it onto the C160 when I converted to hydro, so now I have the C160 with hydro, hydraulic lift and electric clutch. this is one sweet tractor to drive and cut with now.
