wheelhorsin1974
1998 314-8 clutch grabs
wheelhorsin1974
very hard to pull out without getting whiplash. very annoying. would a new belt help???
gwest_ca
The drive belts must be completely covered with fabric. Some have raw rubber sides and they will not slip as the design calls for. You may also have a shock damper connected next to the belt idler pulley that is not working correctly. Many remove it and use the spring used on the earlier models to pull the clutch rod back on the left side. The spring hooks into a web above the left axle housing.
Garry
wheelhorsin1974
As always. The answers i need. Thanks. I appreciate it
decksetter
My 416-8 did that, the problem ended up being the footrest was too tight and holding the side cover in on the pulley.
wheelhorsin1974
Thanks. Ill check into all of these possible issues. Appreciate it guys.
