prpldude 0 #1 Posted August 10, 2008 Ok so what does this do? Dial-A-Hite control rod. I think it has something to do with the mower deck height... should the back wheels on the mower deck touch the ground on a flat surface when the deck is raised??? Any help would be much appreciated.. Share this post Link to post Share on other sites
refracman 167 #2 Posted August 10, 2008 None of mine have it, all hydros .So i would be guess that the deal a height is for the snow plow and implements rather then the controling the deck hieght. Yup your deck wheels should be on the ground. Share this post Link to post Share on other sites
rustbucket 4 #3 Posted August 10, 2008 no idea but as seen most of the experts have chimed in. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted August 10, 2008 The Dial-A-Hite control works best with rear mounted implements such as furrowers, cultivators, rototillers, or moldboard plows. It's there basically to consistently keep the depth of each consecutive pass. It can also come in handy for leveling dirt with the dozer or grader blade, but I prefer to regulate the height by hand. I can't remember your exact model of tractor, but the rubber stops on the deck carriage should be against the bottoms of the footrest boards when the deck is in the travel position. You may need to adjust the lift linkage to gain more height. If your deck is set to the highest cutting position the wheels will be very close to the ground when the deck is raised, but they shouldn't touch on a level surface. Share this post Link to post Share on other sites
prpldude 0 #5 Posted August 10, 2008 Great.. TY for the help... I"ll adjust the lift linkage a bit then... it does seem like there is a lot of "slop" when I raise and lower the deck... Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #6 Posted August 10, 2008 Perhaps this will help you: Share this post Link to post Share on other sites
mailman 1 #7 Posted August 10, 2008 Hey TT, Thats a great pic for help. Definately a saver! Thanks. Share this post Link to post Share on other sites
prpldude 0 #8 Posted August 11, 2008 Yes TT ty for the pic... that will help alot. Share this post Link to post Share on other sites
