Jbo13 0 #1 Posted April 18, 2013 I'm looking at a 416-8. It's got 48 inch deck And rear wheel weights. Anybody have one of These tractors and any pros or cons. Thanks Share this post Link to post Share on other sites
baerpath 517 #2 Posted April 18, 2013 What motor does it have the Kohler or the Onan ? That way we can get a yr on it. Should have an 8 pinion rear in it so thats a good thing. I've had a couple with the Kohlers in them and have one with the Onan in it, That will be looking for a new home soon Share this post Link to post Share on other sites
Jbo13 0 #3 Posted April 18, 2013 It's got the onan with less than 800 hours. I'm Pretty sure I can get for 500 Share this post Link to post Share on other sites
Tankman 3,523 #4 Posted April 18, 2013 It's got the onan with less than 800 hours. I'm Pretty sure I can get for 500 I would certainly take a look. My 416-8 is a Kohler. I love this spirited Stallion. I have a 520-8 Onan in my Herd and it is quickly becoming my favorite Horse. Only 'cause of the engine sound and the power. This Horsey climbs! Mows! All effortlessly too! Welcome to the forums. :smile: Share this post Link to post Share on other sites
Jbo13 0 #5 Posted April 18, 2013 Thanks for the info guys. I had a c-161 but broke A rod and never got it going again. I've heard Good things about the hydro models but The eight speeds seem to me would be stronger Those 520-8s are pretty rare from what I've seen! Share this post Link to post Share on other sites
papaglide 542 #6 Posted April 18, 2013 I have one with an Onan in it. If it had a 48" deck it would be my favorite by far! Awesome power, awesome cut with the 42" deck, it will push snow any where I want it too and probably the most comfortable tractor that I have ever driven! You will not be disappointed! Share this post Link to post Share on other sites
Shuboxlover 482 #7 Posted April 18, 2013 I would certainly take a look. My 416-8 is a Kohler. I love this spirited Stallion. I have a 520-8 Onan in my Herd and it is quickly becoming my favorite Horse. Only 'cause of the engine sound and the power. This Horsey climbs! Mows! All effortlessly too! Welcome to the forums. The 416 with a Kohler is on my short list!! But a 416 with a good running Onan would suffice....if it runs good, that's a good price!!!!!!!!!!!! Share this post Link to post Share on other sites
decksetter 50 #8 Posted April 18, 2013 I have a 416-8 with an Onan, great tractor! Pushes more snow than I would have believed. Onans are really mean engines, but look at the condition of the tractor pretty close... hopefully if it's a well cared for tractor the engine has been taken care of too. It will probably need its valves adjusted. Share this post Link to post Share on other sites
Jbo13 0 #9 Posted April 18, 2013 Thanks guys for all the info makes my Decision a lot easier Share this post Link to post Share on other sites
Jbo13 0 #10 Posted April 18, 2013 Is the valve adjustment an onan thing Or just on the 16hp version? Share this post Link to post Share on other sites
Shuboxlover 482 #11 Posted April 18, 2013 I adjust all my tractors valves.......(if it's capable of being done) Kohler or Onan. Share this post Link to post Share on other sites
decksetter 50 #12 Posted April 19, 2013 Valve adjustments tend to become a problem more on the Onans though. Do them every couple hundred hours and you'll be fine, I can't remember the recommended service interval. Share this post Link to post Share on other sites
Foozerush 40 #13 Posted April 19, 2013 I have a 416-8 with the onan.... Love it... Pushed a ton of snow this year with it. I have the 42 SD deck and mows fine. As everyone states how they love the sound of the onan, I totally agree, they sound so cool. The only things that I had to fix on mine was a short in the headlights, put a clutch return spring on because the gas shock thingy quit working, and tighten the rivit on the throttle lever pivot so the lever would keep the ole onan humming at high RPM's. Keep grass out of the flywheel screen to help keep it cool. Also check to make sure the rubber boot is not wore out on the 1-2-3-r shifter on top of tranny, seen a lot of post of other members replacing worn out ones. Hope you get it, you won't be Disappinted!! Gregg Share this post Link to post Share on other sites
papaglide 542 #14 Posted April 19, 2013 The 416-8 is an awesome tractor! Share this post Link to post Share on other sites
k29349 1 #15 Posted April 19, 2013 I love my Onan 416-8. I could'nt believe the pulling power of such a small tractor. Share this post Link to post Share on other sites
Jbo13 0 #16 Posted April 19, 2013 Thanks for all the info! Next question would be what attachments would fit this model Share this post Link to post Share on other sites
leeave96 490 #17 Posted April 19, 2013 Thanks for all the info! Next question would be what attachments would fit this model Everything!!!! Except maybe a 60 inch deck. :) Share this post Link to post Share on other sites
Jbo13 0 #18 Posted April 19, 2013 Ok thanks! I was pretty sure but figured I Would ask the experts! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,765 #19 Posted April 20, 2013 You can get to an attachment list here https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro Type in 416-8 and select your model from the list. On the right is a link to the attachment list. Then clicking on an attachment model number will take you to the parts list in most cases. These are what were sold at the time so often there are many more older and newer models that will also fit. Garry Share this post Link to post Share on other sites
can whlvr 994 #20 Posted April 20, 2013 im surprised no one has mentioned to fix the 161,if the rod didnt destroy the engine i would rebuild it,the 16 hp kohler is a very good motor,and the c serires are great tractors and can use all the attachments the 416 can,basically they are very similar tractors,i have a few 400 series tractors and a few c series,i love both Share this post Link to post Share on other sites
Jbo13 0 #21 Posted April 20, 2013 Looking back I wish I would have but you no How that goes Share this post Link to post Share on other sites
Jbo13 0 #22 Posted April 20, 2013 Well thanks for all your info guys but my 416-8 Today. It needs a few things but mowed with It and it runs great. Thanks a lot!!! Share this post Link to post Share on other sites
Rbmezick 0 #23 Posted September 28, 2014 Shifter on my 416-8 came out. Can't tell what transmission it even is to find a manual. Probably new sometime around 1972. Any advice? Share this post Link to post Share on other sites
