papaglide 542 #1 Posted April 18, 2013 Well I was out riding my 1996 416-8 around the yard when about 15 minutes into my run I started to notice that my exhaust had a bluish tinge to it and there was quite a bit of it. I am not quite sure what is wrong with the engine. Burning oil for sure but why? Thanks. If this helps there are 956 hours on the tractor. Share this post Link to post Share on other sites
Hodge71 691 #2 Posted April 18, 2013 Not sure what to tell ya on that Papa. I have a '96 416-H with over 1700 hours on it and it doesnt burn a drop. Although I have a sneaking suspicion that the PO's Dad had it rebuilt at some point. Its either that or I have the luckiest Onan made with how these things chuck valve seats around 1000 hours. Is there any chance that you might have sme oil leaking past the valve guides? Has the motor been opened up ever for decarboning or anything else? Share this post Link to post Share on other sites
leeave96 496 #3 Posted April 18, 2013 (edited) Is the crankcase over filled with oil by chance? Edited April 18, 2013 by leeave96 Share this post Link to post Share on other sites
papaglide 542 #4 Posted April 18, 2013 Maybe.I did do an oil change on it. I thought that I put just enough in it to the full line. Maybe I put in too much? I will check it when I get out of work. If it is overfilled, should I just drain some? What damage could I have done to the engine? Thanks. Share this post Link to post Share on other sites
leeave96 496 #5 Posted April 18, 2013 Reason I said overfilled is I did that to another color tractor of mine and got some blue smoke - just a few puff's, but it made me stop and check things and I corrected it. I just opened the drain a bit and let some oil out. If I let to much out, I'd just add some fresh oil to bring it back to level. I don't think I did any harm to the engine - seems to be running OK Share this post Link to post Share on other sites
papaglide 542 #6 Posted April 18, 2013 Thanks for the advice. Hopefully this is all it is! Share this post Link to post Share on other sites
wheeledhorseman 579 #7 Posted April 18, 2013 Not sure what to tell ya on that Papa. I have a '96 416-H with over 1700 hours on it and it doesnt burn a drop. Although I have a sneaking suspicion that the PO's Dad had it rebuilt at some point. Its either that or I have the luckiest Onan made with how these things chuck valve seats around 1000 hours. Is there any chance that you might have sme oil leaking past the valve guides? Has the motor been opened up ever for decarboning or anything else? From what I've read on the forum the 16hp doesn't suffer like the others seem to. Mine has also passed the 1700 hour mark and runs beautifully (now I've sorted the manifold leak) and doesn't burn oil. So there's every chance its something simple like oil level. Good luck. Andy Share this post Link to post Share on other sites
papaglide 542 #8 Posted April 18, 2013 Thanks, Andy! Share this post Link to post Share on other sites
CRE1992 143 #9 Posted April 18, 2013 Like others said check the oil level, and also check the crankcase breather to make sure it isn't clogged up Share this post Link to post Share on other sites
papaglide 542 #10 Posted April 19, 2013 Thanks everyone! I will check it out tomorrow and will definitely give an update. Share this post Link to post Share on other sites
