JUSS10 250 #1 Posted April 16, 2013 The reason i am asking is i picked up a k91 for an rj project and got it running really well but it only has the fan shroud sheet metal. It was a model that had the top mounted tank and i think i still have the tank mount so the side tins are built into that but I'm just curious how crucial the side tins and engine head tin is. The Clinton engines i got with it don't have a tin on the head and i know of other engines that don't as well. I don't plan to work this tractor hard, just putt around with it most likely. Justin Share this post Link to post Share on other sites
Jim_M 179 #2 Posted April 16, 2013 It will probably survive but it would be better if you had all of the tins on it. Share this post Link to post Share on other sites
scWHhauler 96 #3 Posted April 16, 2013 Just rember that it is a air cooled engine. Share this post Link to post Share on other sites
SousaKerry 503 #4 Posted April 16, 2013 I have had several larger Kohler engines with the top piece missing, never had a problem yet. Share this post Link to post Share on other sites
JUSS10 250 #5 Posted April 16, 2013 right, but the fan shroud still shoots air over the head and sides of the cylinder walls, I just don't have the tins that keep it from moving away from the fins. I still have the fan shroud. Guess I'll see if i can track down some tins Share this post Link to post Share on other sites
Jake Kuhn 1,598 #6 Posted April 16, 2013 the side tin piece is still available on parts tree, but the top tin you will have to find used if you are looking for them. ~Jake Share this post Link to post Share on other sites
JUSS10 250 #7 Posted April 16, 2013 i may just draw them up and have them laser cut at the local shop that does that for us. should be pretty cheap Share this post Link to post Share on other sites
Jim_M 179 #8 Posted April 16, 2013 The side tins are the most important ones, you still get a good amount of air over the head with the top tin missing. Having all the tins is still the best though. After all, Kohler put them on for a reason. Share this post Link to post Share on other sites
Jake Kuhn 1,598 #9 Posted April 16, 2013 side tins are 7 or 8 bucks on parts tree, so most likely cheaper to buy that one than have it cut out. Share this post Link to post Share on other sites
